FFMPEG lit des flux RTMP !!!
Je viens d'apprendre que les flux rtmp pouvaient être lus à l'aide de FFMPEG .
http://forum.wiziwig.eu/threads/49818-Swiss-TV-(German-French-Italian-English)?p=1681896#post1681896
Ci-dessous un essai effectué :
fmpeg -i "rtmp://edge1.stream-server.org/livestv/ token=LALALALA.YOU.GUYS.SUCKS swfUrl=http://stream.live-stream.tv/player.php pageUrl=http://www.live-stream.tv/online/fernseher/3plus.html playpath=3plus.stream" -f mpeg out.mpg
ffmpeg version N-43206-gf857465 Copyright (c) 2000-2012 the FFmpeg developers
  built on Aug  4 2012 16:10:39 with gcc 4.7.1 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --ena
ble-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-li
bnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --e
nable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavutil      51. 66.100 / 51. 66.100
  libavcodec     54. 49.100 / 54. 49.100
  libavformat    54. 22.100 / 54. 22.100
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3.  5.102 /  3.  5.102
  libswscale      2.  1.100 /  2.  1.100
  libswresample   0. 15.100 /  0. 15.100
  libpostproc    52.  0.100 / 52.  0.100
Metadata:
  duration              0.00
  width                 720.00
  height                404.00
  videodatarate         0.00
  framerate             12.50
  videocodecid          7.00
  audiodatarate         125.00
  audiosamplerate       48000.00
  audiosamplesize       16.00
  stereo                TRUE
  audiocodecid          10.00
  encoder               Lavf55.12.100
  filesize              0.00
Input #0, flv, from 'rtmp://edge1.stream-server.org/livestv/ token=LALALALA.YOU.GUYS.SUCKS swfUrl=http://stream.live-stream.tv/player.php pageUrl=http
://www.live-stream.tv/online/fernseher/3plus.html playpath=3plus.stream':
  Metadata:
    encoder         : Lavf55.12.100
  Duration: 00:00:00.00, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: h264 (High), yuv420p, 720x404 [SAR 1:1 DAR 180:101], 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 48000 Hz, stereo, s16, 128 kb/s
[mpeg @ 02926020] VBV buffer size not set, muxing may fail
Output #0, mpeg, to 'out.mpg':
  Metadata:
    encoder         : Lavf54.22.100
    Stream #0:0: Video: mpeg1video, yuv420p, 720x404 [SAR 1:1 DAR 180:101], q=2-31, 200 kb/s, 90k tbn, 25 tbc
    Stream #0:1: Audio: mp2, 48000 Hz, stereo, s16, 128 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (h264 -> mpeg1video)
  Stream #0:1 -> #0:1 (aac -> mp2)
Press [q] to stop, [?] for help
frame= 2345 fps= 27 q=31.0 size=    5492kB time=00:01:33.72 bitrate= 480.1kbits/s dup=15 drop=0
Re: FFMPEG lit des flux RTMP !!!
Merci pour l'info ça peut être intéressant en cas de problème avec rtmpdump !
Il y a une subtilité dans l'écriture du lien .
Toutes les données du flux doivent se situer entre les 2 double-guillemets :
fmpeg -i "rtmp://... .stream" -f mpeg out.mpg
Lire http://rtmpdump.mplayerhq.hu/librtmp.3.html , pour + d'infos concernant la gestion des espaces .
On écrira WIN\2012,0,0,77 ( au lieu de "WIN 12,0,0,77" ) .
